Hi, Sorry, to put this in English but my German is terrible. Does anyone know to to access to floor below the table? I try to remove the front pannel but that is still stick when I remove all the screws. Thanks in advance! Hi, Sorry, to put this in English but my German is terrible. Does anyone know to to access to floor below the table? I try to remove the front pannel but that is still stick when I remove all the screws. Thanks in advance! Hi, AFAIR the cable should go under the window behind that panel, which is pretty easy to remove. The podest ist one of the fist parts to be installed by Weinsberg, so you would need to remove lots of other things. Can't you remove that grill on the front? Using a stiff guidance wire could be usefull as well. BR Hi, AFAIR the cable should go under the window behind that panel, which is pretty easy to remove. The podest ist one of the fist parts to be installed by Weinsberg, so you would need to remove lots of other things. Can't you remove that grill on the front? Using a stiff guidance wire could be usefull as well. BR Hi, Thanks for your reaction. The part below the windows was my second best option because I would prefer it to wire it under the floor of the table. I am using a stiff guidance but unfortunately no luck sofar 🙂 It must be possible as I saw that the previous owner has from the box where the EBL is to the accu (below the front seat) a wire for the solar panels. The grill on the front is glued and very hard to remove that I am afraid breaking something. I tried a few times with a stiff wire but it seems that something is blocking underneath. I will try a few times again and if I got it not working I will go for the second best option. Hi, Thanks for your reaction. The part below the windows was my second best option because I would prefer it to wire it under the floor of the table. I am using a stiff guidance but unfortunately no luck sofar 🙂 It must be possible as I saw that the previous owner has from the box where the EBL is to the accu (below the front seat) a wire for the solar panels. The grill on the front is glued and very hard to remove that I am afraid breaking something. I tried a few times with a stiff wire but it seems that something is blocking underneath. I will try a few times again and if I got it not working I will go for the second best option. Can’t you use the wire between EBL and battery to get the new wire underneath the floor? Arno Can’t you use the wire between EBL and battery to get the new wire underneath the floor? Arno I was thinking about this but I am afraid if something goes wrong I have now wire at all anymore 😉 I was thinking about this but I am afraid if something goes wrong I have now wire at all anymore 😉 Can’t you use the wire between EBL and battery to get the new wire underneath the floor? Arno That is also my idea: use the existing wire as taut wire. Maybe also, if you own or can borrow an endoscope camera to see what is going on in the underground Can’t you use the wire between EBL and battery to get the new wire underneath the floor? Arno That is also my idea: use the existing wire as taut wire. Maybe also, if you own or can borrow an endoscope camera to see what is going on in the underground Hi, I finally made it. I used another smooth stiff cable and tried many times and suddenly it worked, yeah! Then with this cable I pulled trough the big one. So now I can continue connecting my converter to the switching station that's switch automatically between external power and convertor power 🙂 Thank you all for your suggestions! Hi, I finally made it. I used another smooth stiff cable and tried many times and suddenly it worked, yeah! Then with this cable I pulled trough the big one. So now I can continue connecting my converter to the switching station that's switch automatically between external power and convertor power 🙂 Thank you all for your suggestions!🇬🇧Cable from Accu until floor to EBL
PN an: Matthias![]()
PEPPER MG 2019 Peugeot 120kW
PN an
pimienta![]()
